I tried all the settings but the temperatures are not dropping. What can I do?
Core at 1350 with 800 VDD - mem at 890…
You kill your GPU’s…
Also remove DPM value…
You have stock bios on all gpu’s???
i tried the new settings, but the result did not change
Core Temp, C 53° MEM Temp, C 106°
what should I do?
Maybe its time to clean up your GPU’s… also thermal paste …
