I recently dug out my ASUS B250 Mining Expert motherboard, and setup my first farm and worker last night.
The system specs are as follows:
CPU - intel i3-6100T
RAM - HyperX 8GB DDR3
SSD - 512GB (spare 2.5" SSD)
MB - ASUS B250 Mining Expert
GPUs - see below
PSU - EVGA 1000 Watt GQ
I have a Radeon RX590, Vega FE and RX 6800XT setup. During the initial setup I was not able to have the Vega and 6800XT mine for some reason.
I then swapped in a EVGA 1070Ti to have the following : RX 590 + 6800XT + 1070Ti
I have a Vega 64, and decided to swap out the RX590.
I turned the worker/system off, and replaced the RX590 with the Vega 64; However, when I powered the worker back on, it isn’t communicating with the HiveOS farm web portal.
The Overview of the worker still shows the previous setup with the RX590, 6800XT and 1070Ti? It appears that it has lost connection?
I have cleared CMOS (unplugged and pulled battery for 1 minute), manually powered it on and off.
Since I just restarted and have not been hashing yet, would it be easier to delete the worker and create a new one and drop the rig.conf file into the SSD?
