Asic hub
Hello, I want to know how to download the firmware and how to install it from the asic hub for an s19.
first install asic hub, add your farm hash and add the s19 to asic hub, then under asic hub settings, change the branch to testing and install the latest version.
then back in hiveos on the asic, in the run command box, run air-install followed by the link to the firmware for your model Hive Downloads
If you get stuck, contact support via live chat on hiveon.com or email [email protected] for fastest response
Hello, I want to know how to install the hive firmware on an S19 via SD please.
have you read here: Installing guide S19, S19J, S19JPRO, S19PRO, T19
it gives me that error:
           failed to found installer in directory "C:\\Windows\\TEMP\\asic-hub\\cache\\xilinx\\S19A"
where are you seeing this error? asic hub is not needed if running hiveon firmware from sdcard
I want to install it by the air install command
if you want to install to SD card you need to follow the instructions in the link above, you can update remotely afterward, but cannot install to an sdcard remotely
Hello, I would like you to explain to me how to install it remotely with the air install command.
what model specifically do you have?
is the asic added to your farm in hiveos through asic hub?
you do not want to install to sd card, correct?
I need to install the Hive firmware on my Antminer S19. I’m doing it with the air install command, but it gives me an error.
" Process exited with status 132 from signal ILL "
This is the error I get from the air install command, The device has the original Bitmain firmware.
what is the date on the original firmware? please send what command you’ve ran, which model specifically you have as well, the more info the better
Linux 4.6.0-xilinx-g03c746f7 #1 SMP PREEMPT Fri Sep 17 20:24:52 CST 2021
tengo ese problema con el asichub
