AS Mining: RTX 5060 TI 16 Gb Connection Error, Driver Advice?
RTX 5060 TI 16 gb can’t connect to pool – connection keeps failing. Tried switching pools, miners, even wallet (Kaspium) – no luck. Had a similar issue on ERGO before and fixed it by rolling back to a specific older driver I found here on the forum. Anyone run into the same problem with 5060 and found a working fix or driver version?
What driver are you running?
570.172.08
driver should be fine, possible the miners you are using dont support that gpu?
Try switching ports DisplayPort to HDMI or vise-versa, had a card that would keep screwing up, thought about it for a day switched to DP port with adapter… wala problem solved…
