i think your first PSU is more loaded than needed. You are using 24 pin splitter to power the mobo right? and also powered the additional power plugs on the mobo right?
i think your first PSU is more loaded than needed. => Loaded @ 73% (770W used for 1050W PSU1
You are using 24 pin splitter to power the mobo right? Yes
and also powered the additional power plugs on the mobo right? Yes, all the Mobo with PSU1.
I can do a try by switching a 3080 of PSU1 and a 3070 of PSU2 in order to see if there is a difference.
Try it. Swithc one gpu to the second psu. The calculation of the max power you can draw from a psu is different. If the psu is lets say 1000 watts it depends of its rating gold silver platinum , 80% 90 or what ever. Lets say its 80% then the real watts you can pull from a 1000 watts psu are 800 in reality. So you are close to max.
rkwjunior, can you share OC for 3070s?
I have 64.3 MH with 200/3100/130 and 130W consumption.
With your OC for 3080s, I have about 99.7 Mh/GPU and 225W with T-rex miner.
Only for 1 I need to set 1060/2050/0 or I will have errors and miner reboot.
Ya, your waaaaay to high in ur memory. Thats gonna kill ur card. Max is 3000.
3070s.
1070 absolute core
2600 mem
Put power limit at 130 but you really don’t need it cuz of the absolute core clock power control.
62.3 MH at 110-115 watts depending on GPU
3080 I do
1070 absolute core
2150 mem
Power limit is 230 but not needed.
99 mh at 208 -215 depending on GPU
Set an overclock delay of 30 seconds, that will help invalids after re boot
Currently I have 3060 ti, 5 right now running. Anyone see any improvement required.
