Hello.
I would like to know if these settings are correct. I am using Trex Miner 0.24.2 and LHR video cards are unstable, going up and down a few Mhs all the time.
And another doubt is that a 1660s and 2060s every so often gives me an error. Is it because of too much OC?
Today I added a Zotac RTX 3060 LHR and I see that the 3 LHR cards with the TRex Miner 0.24.2 are left in LHR69 mode but with a very unstable hashrate.
RTX 3080LHR between 67 to 72mhs.
RTX 3060Ti LHR between 38 to 42mhs.
RTX 3060 LHR between 33 to 35mhs.
Any recommendation?
I was able to solve the problem. It was the Nvidia driver. I was using version 460 that brings the HiveOS image when it is installed on the USB pendrive. I updated to the latest version 470 and now it is more stable, the LHR lock does not appear as much in TRex Miner 0.24.2 and also added some extra Mhs.
does any have a palit 3060 ti dual lhr, i can’t get the best oc for this card.
It depends a lot on the brand of memory you have. The hynix are different from the rest. I have a PNY with Hynix and the overclock is different from Samsung or Micron. Check this website and see if any configuration works for you.
https://www.hashrate.no/
