Any way to restore mining without having to reboot if I lose Ethernet for even a second?
I’ve noticed that if I lose my ethernet connection for even a second, hive OS starts acting up and stays disconnected from then on. This is incredibly annoying because sometimes my ethernet drops for a second or two, and I don’t want it to completely fuck over my hive OS. Is there any way to not make hive OS permanently go offline if I lose my ethernet connection for even a second? Thanks.
Either:
  1. Fix your cabling or network equipment causing this. Wired connections shouldn’t drop.
or:
  1. Use Hashrate watchdog
or
  1. Buy a cheap 4/5 port ethernet swtich
The reason for my asking is that sometimes I need to disconnect the ethernet port. From what I know, using hashrate watchdog will reboot the rig.
