Antminer S19 keeps disconnecting from Hiveon ASIC Hub
I setup ASIC Hub to launch my Bitmain Antminer S19 and for some reason the miner has only stayed “connected” to Asic Hub for an hour at most, but now keeps showing up as disconnected when looking at Hive OS stats. Logging into the miner itself shows that it’s connected to my network fine, as well as mining correctly to the pool, so it seems like it’s just the Hive OS connection that isn’t stable. Any recommendations?
