Antminer S17 Pro and T17
My mining machine has some problems. After using the hiveon system, it does not work normally. Other antMiner mining machines indicate that the temperature is too low, but the hiveno prompts are these. Has anyone encountered it? There are about 20 such, I am preparing to uninstall the hiveon system, which requires ubuntu system, I am still looking for a solution!
1.591729] NET: Registered protocol family 10
[ 1.606346] sit: IPv6 over IPv4 tunneling driver
[ 1.610573] NET: Registered protocol family 17
[ 1.613828] can: controller area network core (rev 20120528 abi 9)
[ 1.618671] NET: Registered protocol family 29
[ 1.621873] can: raw protocol (rev 20120528)
[ 1.624766] can: broadcast manager protocol (rev 20120528 t)
[ 1.629112] can: netlink gateway (rev 20130117) max_hops=1
[ 1.633578] zynq_pm_ioremap: no compatible node found for ‘xlnx,zynq-ddrc-a05’
[ 1.639406] zynq_pm_late_init: Unable to map DDRC IO memory.
[ 1.643876] Registering SWP/SWPB emulation handler
[ 1.649266] hctosys: unable to open rtc device (rtc0)
[ 1.653631] ALSA device list:
[ 1.655204] No soundcards found.
[ 1.657677] RAMDISK: gzip image found at block 0
[ 4.651846] EXT4-fs (ram0): couldn’t mount as ext3 due to feature incompatibilities
[ 4.669015] EXT4-fs (ram0): warning: mounting unchecked fs, running e2fsck is recommended
[ 4.676164] EXT4-fs (ram0): mounted filesystem without journal. Opts: (null)
[ 4.681918] VFS: Mounted root (ext4 filesystem) on device 1:0.
[ 4.686829] devtmpfs: mounted
[ 4.689627] Freeing unused kernel memory: 1024K (c0a00000 - c0b00000)
[ 4.880889] EXT4-fs (ram0): re-mounted. Opts: block_validity,delalloc,barrier,user_xattr
[ 4.908210] random: dd urandom read with 0 bits of entropy available
[ 4.957321] ubi0: attaching mtd2
[ 4.989786] ubi0: scanning is finished
[ 4.998925] ubi0: attached mtd2 (name “configs”, size 8 MiB)
[ 5.003409] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 5.008895] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 5.014414] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 5.020005] ubi0: good PEBs: 64, bad PEBs: 0, corrupted PEBs: 0
[ 5.024670] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 5.030511] ubi0: max/mean erase counter: 131/85, WL threshold: 4096, image sequence number: 533268615
[ 5.038530] ubi0: available PEBs: 0, total reserved PEBs: 64, PEBs reserved for bad PEB handling: 40
[ 5.046384] ubi0: background thread “ubi_bgt0d” started, PID 708
[ 5.061285] UBIFS (ubi0:0): background thread “ubifs_bgt0_0” started, PID 711
[ 5.127203] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name “configs”
[ 5.133353] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 5.141932] UBIFS (ubi0:0): FS size: 1396736 bytes (1 MiB, 11 LEBs), journal size 888833 bytes (0 MiB, 5 LEBs)
[ 5.150570] UBIFS (ubi0:0): reserved for root: 65970 bytes (64 KiB)
[ 5.155557] UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID 2DF45C66-6704-40C6-8A39-DECF1A4EC802, small LPT model
[ 5.189135] ubi1: attaching mtd5
[ 5.675752] ubi1: scanning is finished
[ 5.686805] ubi1: attached mtd5 (name “reserve1”, size 128 MiB)
[ 5.691506] ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 5.696993] ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 5.702505] ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 5.708104] ubi1: good PEBs: 1020, bad PEBs: 4, corrupted PEBs: 0
[ 5.712918] ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 5.718782] ubi1: max/mean erase counter: 968/243, WL threshold: 4096, image sequence number: 1269816314
[ 5.726981] ubi1: available PEBs: 0, total reserved PEBs: 1020, PEBs reserved for bad PEB handling: 36
[ 5.734966] ubi1: background thread “ubi_bgt1d” started, PID 720
[ 5.751308] UBIFS (ubi1:0): background thread “ubifs_bgt1_0” started, PID 723
[ 5.820641] UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name “reserve1”
[ 5.826872] UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 5.835457] UBIFS (ubi1:0): FS size: 123039744 bytes (117 MiB, 969 LEBs), journal size 6221824 bytes (5 MiB, 49 LEBs)
[ 5.844739] UBIFS (ubi1:0): reserved for root: 4952683 bytes (4836 KiB)
[ 5.850001] UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID 90F589A4-BAC3-4248-95FE-91E276A9FEE6, small LPT model
[ 6.595995] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.625531] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.311409] macb e000b000.ethernet eth0: unable to generate target frequency: 25000000 Hz
[ 7.318207] macb e000b000.ethernet eth0: link up (100/Full)
[ 7.322915] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 21.831446] In axi fpga driver!
[ 21.834517] request_mem_region OK!
[ 21.837912] AXI fpga dev virtual address is 0xcfb38000
[ 21.843549] *base_vir_addr = 0xab013
[ 21.857603] In fpga mem driver!
[ 21.861077] request_mem_region OK!
[ 21.864964] fpga mem virtual address is 0xd2000000
[ 195.272723] random: nonblocking pool is initialized
first run!
