Radeon RX 6700 XT 12272 MB · Sapphire
Samsung GDDR6
Core 1275
700/800/1300
Mem 1075
46.59Mhz (eth) @ 93/94W
how exactly do you go in for each individual card and realize their max?
make a change and note if hashrate and power draw improved. if it did continue that direction until it starts getting worse.
Regarding the fan that you tested with 5%, I must say that in the BIOS of graphics cards, the minimum speed of the fan pwm is specified. Some gpus have at least 30% so that the fan speed is not lower than that.
But some GPUs are such that the speed can not be less than a certain pwm and becomes 0.
This test is for the graphics card BIOS.
But can you explain about the BIOS 5700xt? I moded my 5700xt BIOS but I could never reduce its consumption to less than 105 watts.
vBIOS - yes that could explain why we get 0 fan speed when we go like 5% Max on AutoFan. Do you have exact same GPU? I can share vBIOS for this one.
Radeon RX 5700 XT 8176 MB · XFX
Samsung GDDR6 · 113-180W2NAVI10XT8GD6_MS_191122_W8
this my gpu
This is the exact model of my gpu.
You please share your vbios. I use the parameters you used in my gpu bios gpu.
Sure. It works fine doing 55.5Mh @98w (soft)
1350
750/750/0
905
