AMD has a very low computational power
All my AMD card is to brush the BIOS firmware, AMD hiveos web pages - OC default Settings, nothing GPU1 GPU2 GPU3 force only 3 to 5 m, and then I try to set up DPM 4 V 950 MEM 2250 fans 70%, calculate the force is only part of the work force as normal. May I ask what caused this?
Starting directly under Windows is 30M. Please help me. I’m very upset and grateful.
What miner do you use?
I’m see high cpu load averages
[quote=“HaloGenius;3369”]What miner do you use?
I’m see high cpu load averages[/quote]
claymore
When I removed the AMD -oc setup, I only set the fan speed 70%, the calculation force is shown in the figure.
Try to switch the MB bios setting.
PEG port Configuration to Auto or GEN2
other PCI Express setting Auto
