After 0.5-52 upgrade, XMR-Stak does not run!
Hi;
When i am using XMR-Stak on 0.5.-51 version, there was not any problem but it does not work after upgrade to 0.5-52.
I am getting these errors continuously:
[2018-05-19 06:15:29] : Error CL_INVALID_ARG_INDEX when calling clSetKernelArg for kernel 1, argument 4(input buffer).
[2018-05-19 06:15:29] : Error CL_INVALID_KERNEL_ARGS when calling clEnqueueNDRangeKernel for kernel 2.
I have same problem after upgrade
i hope can be fixed soon
currenly back to 51 with:
apt-get install -y --allow-downgrades hive=0.5-51
i’m mining cn-heavy coin
The same problem aftrer upgrade. On sumokoin only. AMD RX570
Same problems on RX580 rigs.
The same problem XMR STAK GPU aftrer upgrade 0.5-52. On haven. AMD RX570, 470, 480.
Has any1 tried this after a Image upgrade directly to 51 or 52 and got the latest drivers?
Same here, downgraded back to 51 to get it to work… remove this “I NEED MINER” fork… its not reliable
Has any1 tried this after a Image upgrade directly to 51 or 52 and got the latest drivers? = I tried, didnt make a difference with newer Linux Kernel and latest Drivers.
when is fix?
same error here! hash went up 13% but this stupid error… i hope it gets fixed
new release 0.5-53, use Miner fork: fireice-uk in “Wallets” tab. Works fine.
Yes, after the upgrade(0.5-53) there is no problem.
Thanks…
however is it possible to make the indeed for work with Haven? anyone tried? hash is interesting lol
@Florent
It does not make sense to look at the hashrate of the inoperative miner
But yes it’s true windows binary from Indeed miners works fine at cn-heavy
i know but there is a gap between hash of indeed on windows and hash on hive, we need hive to have same perf or better than windows or else it will not push people
Trying to run XMR-STAK or cpu-miner does not work. the configuration file in /hiveos/cpuminer-opt (for example) get touched (date and time changes) but nothing get written to it. If I manually edit the file or cp a correct configfile over cpuminer.conf, it does work. Can you fix this please? I have re-installed with a brand new image and the problem is still there.
@SpriterQC
It’s completely unclear what is at stake, especially in one sentence it once two miners
Can you post your settings for xmr-stak, cpuminer-opt?
