AethelBlock Pearl (PRL): PPLNS and SOLO pool settings for Hive OS
Hi everyone, we operate AethelBlock and are sharing our Pearl (PRL) pool settings for Hive OS users.
Mode Stratum TCP endpoint Pool fee
PPLNS prl-pool.aethelblock.com:3333 1%
SOLO prl-solo.aethelblock.com:3334 1%
Pearl uses PearlHash. Use a native PRL receiving address and a miner build that supports PearlHash on your GPU. If your SRBMiner Custom Miner package expects manual arguments, here is a PPLNS example:
--disable-cpu --algorithm pearlhash --pool prl-pool.aethelblock.com:3333 --wallet YOUR_PRL_WALLET.YOUR_WORKER --password x
Replace both placeholders with your own address and worker name. For SOLO, use the SOLO endpoint above. Confirm that shares are accepted and look up your worker in the matching pool dashboard.
We have verified accepted PPLNS shares with SRBMiner-MULTI 3.6.9 on our Linux rigs. If you run into an issue on Hive OS, please share the miner version, GPU model and relevant error line.
Pool dashboard and setup information: https://www.aethelblock.com/
