All the cards will occasionally do this, it started happening when I added the 9th GPU to ETH instead of RVN and I put them in a mining tent which increased the temps. Not sure what could be the definite cause tho. Reverting to its previous setup doesn’t work either.
Have you moved the cables, raisers. they seem pretty hot when you take into consideration that the fans are working 100% speed. you are gonna blow the fans faster than usual.
