Hello dear developers! I kindly request you to add the possibility of more advanced overclocking settings. Due to the large variety of coins available for mining at the moment, each coin has its own optimal overclocking settings. Often, it is necessary not only to adjust the memory and core clocks but also to specify additional offsets directly in the miner.
This is highly inconvenient. I ask you to add the following options:
- Core clock offset
 - Core clock lock
 - Memory clock offset
 - Memory clock lock
 - Power limit
This way, it will be possible to fine-tune overclocking settings more precisely and choose the optimal balance between power consumption and mining efficiency.
