Adding Farm Hash to S9, not working. Not joining farm
Adding Farm Hash to S9, not working. Not joining farm. Kind of at a loss on what to do here. I cant SSH into the device to look at any other config info. It gives me connection denied messages. Any ideas or suggestions on how i can get it to join the farm properly?
For some reason when i did the farm_hash, i also had to enter in the http://api.hiveos.farm URL on the one ASIC while on the other one i didn’t have to. Go figure but maybe this helps someone out?
I’m having the same issue with an L3, and it started just a couple days ago as well. It worked fine for several days and I could see it in my rig manager but now it just won’t stick. I’ll apply the farm hash and the logs look fine but as soon as I refresh it’s not there. Setting flight sheet worked, the config made it to the rig and it’s mining but can’t see it online…
Running into the same issue - Can’t add s9 to farm using the hash - Has worked for my other 3 asics - Not sure why this one will not join my hive farm. Any ideas?
Any errors or anything?
Not that I’m aware of - I’ve even tried with a 2nd control board. Same problem. I add my farm hash in miner control panel, refreshes saying saved, and then nothing. Typically this is when my phone would fire off a notification that a new device has been added, etc … But nothing happens. The S9 doesn’t appear in my Hive Farm list. Weird right? I can’t figure this one out.
The one thing I keep noticing is, even though the miner is mining and showing hash on the pool, when I try and run ping or traceroute under the network / diagnostic tab, nothing happens.
Did you try typing out the api server as a user mentioned above?
You can also try other api servers, these can be found by clicking on any worker → settings → mirror select, copy one of those and try pasting into the local ip dashboard when configuring the farm hash
Yes, someone made the same suggestions on the discord - Neither work. I just tried again with http://naw.hiveos.farm as well as the ip one http://192.168.222.250 …
Are you able to ping and traceroute api.hiveos.farm?
ping returns: just one ping result
This ping api.hiveos.farm
PING api.hiveos.farm (163.172.125.106): 56 data bytes
traceroute returns: (incomplete)
