A way to get payout 63% of threshold (etc needs more than 3GB now)?
I’ve been mining with R9 280x, and since it requires almost more than 3GB I’m not able to do so anymore. Is there a way to get my balance from pool, since I won’t be able to mine it any longer, and am not able to reach threshold?
Depends on what pool lol Many allow you to change the payout threshold or do a manual request. What are you mining, since you needed more than 3GB since 2019-2020 for eth?
If you are on etc, you still have a few days, and you should be ok. If can’t mine at all, you might need to contact the pool’s support to request the payout. They will hit you with the fees since you are under the limit
This topic was automatically closed 185 days after the last reply. New replies are no longer allowed.
