850w too much power
Im having a problem with my new mining rig. I haven’t been able to get it running because it seems the system draws too much power.
I have 4 nvidia 3070 i was only able to get 1 running. When i add another one the other graphic card simply wont run. I checked the power consumption and with one graphic card its 960 watts. If i put 3 graphic card it will simply trip the power supply.
I took all the graphic cards out and hiveos shows power consumption of 860 watt. That sounds too much for me and i think this is my problem right there. I changed motherboard and cpu its the same problem.
Currently im using
MSI X470 GAMING PLUS MAX motherboard
AMD Athlon 3000G 2-Core, 4-Thread Unlocked Desktop Processor with Radeon Graphic
Any help will be much appreciated
you cant possibly have 860 watts consumption without GPUs… how do you know that the consumption is 860 in Hive without GPUs? have you manually inserted what you PC consumes? HiveOS doesnt usually know what the system consumes.
