Hello fellow miners,
I’m using “Sapphire 6900 xt nitro + se” with “Asus Rog Strix 6800 xt water cooled”
Hashrates seems ok but my miner tends to give “Amd Driver Could not load” error after few hours and card goes to sleep. I have to reset twice a day, lucky if it happens when im not sleeping so I can quick reset, but cant always be this lucky.
I am using NBMiner, and am hoping some of you can help me with overclock setting for both of these cards so I get max efficiency in terms of Mh/Watt and hopefully cards dont fail after few hours.
edit: it is 90% of the time that 6900xt who fails.
Thanks in advance, best regards
