It’s looking like Hive OS, as well as the Mining Applications, require some optimizations for the 6600 XT. Maybe even an image update with AMD Drivers Post 6600 XT release since it’s not as easy to update AMD drivers on Hive OS as it is to Update Nvidia Drivers with Hive OS.
First Issue is that it takes a very long time for the rigs to boot with 6600 XTs, this increases to Red LA numbers before mining even begins. Hive OS is going through way too much to figure out what these 6600 XTs are vs knowing what they are, along with extensive lags internal crashes.
Second issue is that something is killing off the 6600 XT’s after an hour or so. And the Load Average is way too high.
Third issue is after rebooting Mining Apps are giving off errors for the 6600 and not starting at all.
Any tips or tricks would be helpful, but I am pretty sure Hive OS, Mining Apps and Driver optimizations are what’s needed for 6600 stability.
