Nice tips ,thanks for posting.I will try increasing the Memory Clock over the weekend and post results
Maybe you can change a miner program. I am using Gminer and the latest system.
I used TeamRedMiner and NBminer at the begining. No matter what settings I am using, I only get 28MH/s. After I switch to Gminer, it just jumps up to 31M/s with no OC. And after using the OC found from this forumn, I finally reach to 33MH/S. Hope this would help.
Good luck. 6700xt seems promising
thanks for sharing the OC, using GMiner for my mix rig, 2 of 6600xt hashing 33+mhz and wattage reduced from 60w to 55w when i increased core wattage from 600 to 650, interesting.
bro, how to setting DPM ?
the value of dpm carried over from my previous rx580 polaris gpu when i replaced it with 6600xt, i noticed 6600xt wont allow to set DPM or memory state. maybe future hive upgrade?
after some tuning, my best stable for Sapphire pulse and ASrock Phantom, 6600xt cooling is incredible. running it without extra fan just natural airflows, that save alot of power.
couldn’t agree more with you on the airflow. 6600xt is a really good low end card as per what they advertised. i had my 6600xt packed on a mini rig with just minor gap between the cards and it’s not creating much heat.
any suggestion that i can bump maybe 2 to 3 hash higher? currently doing triple mining with nanominer
eth, eth+zil and xmr
not sure about nanominer, i’m using gminer mining just ETH
