Hello community!
I have a problem with the stability of a 3080 3x Ventus video card, to be more exact the GPU 5.
Besides that the T-rex every so often cuts with an error that said something like CUDA _…
It’s hard for me to have constant hashrate, because my GPU5 turns off, sometimes everything turns off directly with that CUDA error _…
I am cooling the plates well, but there is no case.
What do you recommend me with that unstable GPU5 and with the constant shutdown of the worker?
Check by remove the PL leave it empty…
look for other settings for your video cards
