5700xt overclocking help
Hi guys,
I’m a new miner and I’ve some problems to increase the efficiency of my amd cards.
At the moment I got some radeon 5700xt (XFX) but I only get 51mh/s for 180w each.
How do you reduce the consumption of your cards?
I would like to edit or change my bios but I can’t find any, where are you going to find a new bios?
If you have any other advice, I’m interested.
Cheers
You need to alter the memory timings on the card by flashing a new bios with adjusted memory timings. I have attached a tutorial that you can follow. Then you need to undervolt the card and increase the mem clock till its stable
Thank you mate, I’ll let you know.
