Hi, I installed 4x Aorus 5700 XT cards today, have not yet modified BIOS, set up “popular setting”, it has been solid for about 6 hours, then it crashed and rebooted (teamredminer: GPU0 detected dead)… but after reboot, 1 of the cards do not work at all. The fans are not spinning, LED lights are off, HiveOS doesn’t see the card…
I checked all the cables, they seem to be ok, changed the riser (that did not help), changed the PCIex power cable (that did not help), if I connect another card with the PCIex power cable from the “dead” card - it works. Riser is powered from 6pin (no SATA or something).
So it seems that the card died somehow… is there any help? How can I check if it is really the card or something else. Thanks for any advice, spent couple hours testing everything and googling…
