Hello; What are your 3080ti dual mining overclock settings? I can’t get over 86mh
Hi, what does lock core clock means? Set any value fixed? ex: 1100?
Yes any value above 500 is a locked core clock
Its not about with overclock but i want to ask somethings how much ergo do you get in a day and eth? also is this cards LHR mode ?
Hi. Has anyone experienced a problem with dual mining eth and ton such as mine?
My 3080 ti suprimx has been deteriorating in terms of ton hashrate. I suspect its got to do with its thermal
But i did mine eth only, and was able to reach 110 mhs in stable condition.
Any advices is greatly appreciated.
Apologies for the bad crops. Doing this on mobile
I did try dual mining on Windows and had the same issue like this . not all the cards get the same output in TON. So left it.
