Hey guys,
I have the Gigabyte 3080 Gaming OC and I changed all of the thermal pads in the GPU, because it was thermal throttling. Now I dont have any issues with the MH/s, it is stable, as you can see from the screenshot. The temperatures of the core now are all below 50 degrees, which in my opinion is pretty good.
Nevertheless, I am having two issues. The first is that my autofan is obviously not working. When i turn it on I receive two errors at the same time:
Autofan: unable to set fan speed
GPU driver error, no temps
Now I have turned it off…
My second issue is with the card being extremely hot. You honestly cannot touch the backplate it is that hot, which kind of bothers me. The other card that you see on the screenshot is an ASUS ROG STRIX 3080 OC and I didnt need to change the thermal pads and it is working good for now.
Is anyone experiencing the same issues?
Do you think it is normal for the backplate of the card to be so hot?
