This is my second 3070ti rig for rvn. My first rig is running perfectly at 1500 core 2100 mem. This new rig is running at 1500 core and 1500 mem and its crashes continuously. Why would the same exact rig be failing when its being run at much lower settings? How can I fix this?
On your new Rig u have the same hardware and same Version of hive os ?
yes, the same everything down to the risers. PSU is a different model but still compatible
Put one card only and check …If yes put another one …
I have that problem,3 cards normal and one is problematic,on thath one i just put pl on 270w and nothing for core and mem,rig running normal for a months.
3070ti aorus
Try with this alone on another board if you have to see what it does…
