Can anyone give a hand with this, please.
I have a 3070ti 8gb Vision OC card that as soon i put it in my rig is making the rig to go in High LA and reboot.
What i tried so far
- I replaced riser - same result
- I replaced SSD with a better one - same result
- I reinstalled Hive OS new farm new config etc - Same result
- I have tried the Hive OS beta - same result
- I stopped mining on CPU - Same result
- I used another motherboard - same result
- I used another PSU - same result
- I used the rig without 3070 ti - All good no problems.
Is it safe to assume is the Overclocking settings and i did try some settings but none worked to be fair.
I would appreciate the help as i want this card in the Hive OS compared to windows pc as i have atm
Many thanks.
