Are you running 100% fan speed? First try that.
If you’re not happy with that you can always upgrade the thermal pads to higher quality ones. Warranty depends on your country.
Yes fanspeed is full. It is not normal i guess right? What can i do anything else ?
add an aux fan or you can try underclocking the memory, they dont throttle until 110c though.
is it harmful for my card ?
