Has anyone encountered this ? Card seemingly looks ok-ish works as good as the other 3070s RTX i got ,but for some reason the FanSpeed although it’s set at 70% shows 0 which is the auto setting.
And i’ve checked it doesn’t work as auto but as the 70% setting i gave it.
Is it a HiveOS graphic glitch ? or do i need to be worried?
I’ve already swapt riser cards just in case didn’t change anything but haven’t tried changing drivers or anything like that cause frankly i don’t know if i should be worried or not.
