3060TI not starting
Just started my rig again with 4 cards on ano, and both 3060TI not working
I have no idea why, can you help me ?
thank for any help
if your 3060tis are showing LHR that means you are on a very old driver. please update your hiveos install by flashing the latest image
you can flash from the device by running hive-replace -s -y and waiting for it to reboot on its own
I updated them, and they are showing now, but still 0% on Zano
Curiously they are heating normaly and consuming power
Any other idea ?
Thanks for help
Is the picture from before? It is still showing the old driver. Try running hive replace again and wait for it to reboot on its own.
I updated the drivers to 550.144.03, looks like that’s the lastest ?
Still have 1.3kw power consumption but it’s not mining
Any idea ?
looks like your settings are probably causing issues. 3800 on the memory is too much for anything besides 50 series gpus, remove OC, check miner log to make sure its working, then fine tune your OC
I changed the miner to Trex and it started working, I don’t know why it wasn’t working
I added a better cooling fan system and it looks like good now, thanks for help
If you see something wrong on my picture juste let me know
