I just finished building my first rig and I have run into a heating issue. Any help would be greatly appreciated. I have changed OC settings, went from T. Rex to Phoenix, etc. I actually did worse on Phoenix than on T.Rex. Got a ton of invalid shares pretty quickly from Phoenix and had none from T.Rex. Could it be my cards are too close together on the rig? I’m lost at this point to be honest. I’m hitting 65-70 degrees on 4 cards. 1 is holding 55-57 and one is 68-70 degrees. The other 3 are going from 62-66 degrees.
Those are the temps I’ve been dealing with. Below is my rig. Running off USB on a 1600w EVGA. The card that is circled is the one getting into the 70s. Hit 72 about 30 mins ago so I shut it down until I figure this temp issue out.
Thanks for any help
