3060ti failing LHR, I've tried everything, I can't solve it HELP PLS!
i see few things to change…but for 7day, i like that
Gotta run what works for you, but dang there are many tools missing in that ancient software load :slight_smile:
Congrats on the week!
Hi
I have similar prob .
Di you solved that?
Tanks
I have same issue with 1of my cards, it has been running for half a year without problems, now it is constantly crashing. currently max oc is 100 on ram, 52mhs, still better then 20 :smiley:
try 1400 core and 0 ram, and check if it is stable. and then go up from there
