t-rex
I hope served my tests
Tried t-rex today. was working not correctly for me. hashrate was ok what was shown in hive. around 124-125 but watching at the pool showed creepy performance. also my cpu load went up from max 0.5 with nbminer to 7-8. which hiveos showed red.
On T-Rex Github there is a issue filled with this meanwhile…
thank you, i didn’t realized it. back to nbminer or i’m gonna try lolminer.
Thank you for the core clock. Back to NBminer, more than an hour so far with this. I can’t find hashrate stats on nicehash, hope it showed correct performance.
lolminer 1.30 also has an issue atm with nicehash.
i´m back to nbminer so long.
Looks like your using much older version of Nvidia driver from you image:
LHR (ver2) won’t work with older drivers at all.
It has been working flawlessly for a day. I tried most of the drivers. But I was able to run it only with the driver in the image. What is your suggestion? Thank you
Do you guys know if the glitch works on drivers newer than 460.93 ? I have a nerfed 3060 and i also got a 3060 lhr v2…and i am trying to profit from both glitch on nerfed and nbminer 70% on lhr 2 (that wont work with 460.93). Or if you guys have any other ideas.(also have 2x3060TI non-lhr along them)
Thanks in advance.
try 90 +150 (2400 to 2600) & (130 to150) PL
Hey Cogito,
I have the same issues only my Hive Shell wont even boot up now…Do you have any ideahow I can get my hive shell to load up?
