3060 TI is being power limited
Hey there, all!
I’m trying to figure out what is going on with my 3060 TI. When I first added it to the board, it was getting about 26 MH mining RVN. I looked up some OC settings, and it dropped down below 10. I changed it back to default with no OC, and it went back to 25. I tried 1 more OC, and it won’t go over 100 Watts no matter what I do. I switched PCIe slots and power, and nothing. I’m completely lost on this and could use some help.
Try running nvtool --throttle to see if its throttling for any reason
This is not normal power limit behavior.
Run nvidia-smi -q -d POWER and check if there’s a software or BIOS power cap.
Also check driver version and if the card is LHR V2 with incorrect strap settings.
Well, I ended up testing it on another PC and within moments it started smoking. Sent it back the the guy that sold it to me.
