Where is the problem
With Nvidia RTX 3060 which is LHR you can reach 26 Mh with T-rex in mining ETH.
With Nvidia RTX 3060 which is no LHR you can reach same result.
I personaly tried with 3060 no LHR to make 50 Mh throught fan trick with mining Erg on Nbminer but when I go back on T-rex and ETH, every few
minutes miner has reseted. In other case miner can’t start because I get error mesage :“TREX: Can’t find nonce with device [ID=1, GPU #1],
cuda exception: CUDA_ERROR_LAUNCH_FAILED, try to reduce overclock to stabilize GPU state”
The question is : Where is the problem, why rtx 3060 can’t reach 50 Mh? In drivers of GPU, algos or something third?
