3060 lhr v2 gigabyte hynix memory (Overclock settings for ergo, flux, etc and rvn) HELP!
Hi, I´m not good at doing oc. Can you help me with getting oc settings for flux, ergo, etc and rvn?
I have a 3060 lhr v2 gigabyte with hynix gddr6.
find out what the algo likes, core, mem, or both. then fine tune from there.
if its a mem heavy algo, find the highest stable mem that gives you highest hashrate.
if its a core heavy algo, find the lowest core that gives you full hashrate, this will likely be on the higher end of the gpus capability, but there are usually diminishing returns for the last few percentage. find your happy spot with hashrate and power.
if its both, do both together.
mine on ergo is set at 1580 core 2260 mem at 158w… but you can go up on core and wattage…memory are at limit
For my 3060 LHRs ERGO I’m set at 1605 / 2000 with a PL of 135. Each card is around 120-122 MH at 102-105 watts.
On my it’s for FLUX I’m at 225 250 at 160. Getting 67.5+/- on each card.
