Hello guys,
I am having problem with downgrading driver for Nvidia right now I have 460.91.03 and I wanted to downgrade to the 460.39.
My card is MSI RTX 3060 12GB Ventus 3x
Running HiveOS - 0.6-209@210831
Using usb 3.1 for OS
How I downgraded driver:
- I did it as my friend who did this before said update hive to the current version
1.1. I threw the rig into maintance mode and rebooted - Hive shell command via web browser line not miner
- used command - Nvidia-driver-update —list
- then picked version - 460.39
- Next download started and finished ok
- Installation finished ok
- Some reinstallation immediately after installation finished ok
- after that I restarted rig and it never load back to hive and having problem starting.
- Problem with running hive and getting error - fixing recursive fault but reboot is needed
After this I need to make new usb and start over coz it never solve recursive fault.
Any ideas?
Thank you a lot
