i am having the same issue here core 1200 mem 1500
mem wont go above 1500 without crashing 40.8 hash stable on phx miner can anyone help with uploading screenshots very new
mine dose 39.4 - 40.8 stable some days it goes uo sometimes down no loss in shared or any invalids but a reset every day helps that card only the micron chips arent as good as the samsungs obviously any bios anyone know of that will fix? all i can suddgest to get mem clock over 1500
I just started using the same. I get 45.84. Thank you for sharing!
te da fallas?
I have two 2060S’s which wont go past 39MH. One is Palit, one is Gigabyte. The common “feature” … Micron memory. I tried all kinds of settings for both but can’t get it to go past 39 if it meant saving my life. Anyone with experience with 2060S’s with Micron memory??? Any help would be appreciated
Zotac 2060s 43.7MH
Core 1010
Mem 1975
I got 42 from 37 by changing memory pads to grizzly and flashing immo3d bios
hi, which inno3d bios did u flash for ur 2060s?. mine is palit 2060s micron and stuck w/ 37.5, can i also asks what is the size of pads u put into ur 2060. thanks
sorry, not inno3rd after all. this 90.06.44.00.5C (kfa2)
though you also need to set PL to max (200) in order to achieve anything too
Thermal Grizzly Minus Pad 8
120x20x2.0mm
I think yes, either it flashes or not. I sggest using latest hiveos/drivers and maintenance mode for flashing. Surely make a backup first of your original bios. My card had the same bios as you.
please share your success
sorry late reply, was waiting for the pads to be delivered, i use the gelid 2mm, and follow all your instructions and it was a success, though now i’m looking for a better way to cool this card now, cause of summer. thank you for ur replies and time good sir, cheers!
I guess your temp is higher as well because your pads transfer heat even better from vram. I would try to increase memory and a cc a bit more if card is not crashing. What I did for cooling, I put another card very close on the back and nothing in front… Yes this card is a pain
用的什么算法?我没胆量这么设置
Hello guys. I am going to create new mining rig with nvidia 20 series of cards.
I am looking for best Investmen, if i understand there is not big difference between 2060 Super , 2070 , 2070 Super, 2080 , 2080 Super card’s?
Only 2060 is about 30-32 MH/s but this others are about 42-45 Mh/s all?
Cuz 2060 super i can buy for 350€ and 2070 Super for 400€, if we speak for 2080 super its about 600-700€. What is better?
Here is list of available cards in my city:
Inno 3D 2060 - 300€
Rog Strix 2060 Super - 350€
Zotac 2060 Super 350-400€
Rog Strix 2070 Super 400€
Evga 2070 - 400€
Msi gaming x 2080 super 600€
I have to buy 3 cards now.
You may want to check the prices on RX 6700 XT, RX 5700 and RX 5700 XT.
RX 6700 XT - 46 MH/s, 68-78 W
RX 5700 - 54 MH/s, 75-89 W
Mining with Teamredminer with R-Mode you would save power.
2060 super are best bang for buck. They only require 1 8-pin power connector also, saving you on power supplies as the 2070 and 2080 both need 2x 8-pin power connectors.
