0.6-213@220129
N495.46
Kernel
5.10.0-hiveos #83
is there any newer?
0.6-213@220129
N495.46
Kernel
5.10.0-hiveos #83
is there any newer?
You could try the beta 510.39.01 driver, but I’m not sure if that will change anything or not. The rest looks fine.
which Firmware u used?
(Sorry the previous link was wrong.)
Hello guys
I founded the solution
I downgraded the Hiveos Firmware following this youtube video and finally it worked!!
For the future HiveOs should update for this 2060 12GB error in its latests firmwares realeses.
I’m using this following firmware: 0.6-212@211130
you can download from hiveos official website: https://download.hiveos.farm/
The complete guide is here and it works for my evga 2060 12GB
MSI RTX 2060 12GB Device 1f03 | minar RTX 2060 12GB en HiveOs BUENA GPU - YouTube
Thanks @Grea . I see now my Nvidia driver is older, although I recreated USB and updated. But how did you update Nvidia driver?
Get into the hive shell or shellinabox and you’ll see a screen of commands, one of them is nVidia-update.
you’ll run that like nVidia-update 470.103
And it will do the rest
nvidia-driver-update
I use 510.54, works like a charm, but not good for lhr.
That’s a bummer to hear. LHR locking in lower?
Thanks for info… What MHR are you getting? with 510.54?
From my experience, N495.46 is good for lhr, but wouldnt display 2060 12gb, anyway it works fine, just without proper name.
Other branches showing 2060 card name but not as good for other cards that are lhr.
