I bought 1660 TI Overlockable, but the overclockk settings is not working… I tried with difference drivers---- 460,495, 470, and I tried a lot of option, but no result, I can’t change options what use the card.
The first card is GeForce 605, I don’t use this for mining, only for OS, baceuse I have CPU without GPU
Can I you help me?
Here is the “settings applied” message result:
===============================================7
Mon Mar 28 13:44:14 EEST 2022
Detected 2 NVIDIA cards
GPU BUS ID : 02
CLOCK : 0 -200
MEM : 0 2200
PLIMIT : 0 70
FAN : 0 0
=== GPU 0, 02:00.0 GeForce GTX 1660 Ti 5944 MB, PL: 70 W, 120 W, 150 W === 13:44:15
SET GPU CLOCKS: 0 MHz
SET POWER LIMIT: 120.0 W
Max Perf mode: 4 (auto)
Attribute ‘GPUGraphicsClockOffset’ was already set to 0
Attribute ‘GPUMemoryTransferRateOffset’ was already set to 0
Thank you!
I removed the card, what I not used, Now tha values are okay
