Hy dear community,
I had 2 workers with RTX 3070 for a total of 12 GPU. ALL gpu are working perfectly in this setup of 2 workers.
I decided to move all the gpu to only one worker.
Now:
- 11/12 gpu are recognised. It is allways the same card with issue (again it was working previously).
- I did some gpu swap testing: same issue, same card. Issue do not care about pci slot, allways the same card with issue.
- I changed all parts of hardware (new riser kit changed 2 times for all swap testing, power cables changed 2 times. So no issue possible with hardware.
- I used B250 mining expert. I have couple rigs with 12 amd gpu, same motherboards and psu(1200w for each section + 400w for atx) and everything working fine.
- It is my first 12 nvidia gpu with Asus B250
If you guys have some suggestions, it will be very appreciate.
Best regards,
