Hello guys! I used to be able to run my 2060 cards between 70-90 watts with lower temperature than I have now. One of the cards is at 65 degrees which I think is alot. This is by far the best hashrates I can get from my cards, and Ive tried to tweak them alot.
Do you guys see anything that might seem out of order? And how can I turn down the power limit without getting the error message. I cant turn it down under 125 watts now on the 2060.
Please feel free to leave any tips on how I can improve my temps, hashrate or anything.
I am using trex miner and after I installed the latest driver I was able to get the temps down by 1-2 degrees on my hottest cards. I also suspect there is some bad airflow I will take care of later this week.
Thank you
