Oke thanks i just apply your oc setting, will see how it goes…
If it goes right, please post your results here. This can help other miners. Have a nice mining
I will do. will let it run with this setup until tomorrow… so i can see if it goes well
until today its been oke, it didn’t stop hashing so i guess its oke…
Ну что как успехи ?
im doing fine…
I have no problem with my 1070x7.
Miner: T-rex
Pool: Ethermine
You have same oc value?
Im using also ethermine pool and nbminer
im havin this issue today…
Apr 12 05:09:15 Test_Rig kernel: [55637.224692][ T945] NVRM: Xid (PCI:0000:01:00): 31, pid=2614, Ch 00000012, intr 10000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_2 faulted @ 0x7f3a_514b8000. Fault is of type FAULT_PDE ACCESS_TYPE_READ
Apr 12 17:04:09 Test_Rig kernel: [98531.029522][ T945] NVRM: Xid (PCI:0000:01:00): 31, pid=28404, Ch 00000013, intr 10000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_GCC faulted @ 0x100_00000000. Fault is of type FAULT_PDE ACCESS_TYPE_READ
Auto fun
its running now with same setting. but i will keep an eye on it to see what happend.
Hello for all community! Here is my oc. I’m taking as hard as I can.
Running stable but FAULT_PDE ACCESS_TYPE_READ was start showing recently.
I don’t know how you guys pulls out of a 1070 38mh with PL below 150W. Max I had 28,7 at 170/1800 60*C
Here’s my OC for a 1070 Strix with Micron memory, actually surprised at how it performs. Had a quite bad perception of how Micron memory would perform.
I only have 1 GTX 1070 G1, but it does ok, Normally its 28.7 but since my last upgrade it has been down to 28.01 for some reason, I also get the same hashrate with 125/1000
I can get it up to 30 with 150/1150 but it crashed after 8 hrs, and I want the card to last a while so Im ok with getting 28mh
