%100 fan speed problem. Autofan has a bug
I use the latest HiveOS version. I have a big problem only on Asus P106-100 6GB GPU rigs. (16 pcs rigs.) Autofan is enabled. Max fan speed is %95 but i always receive %100 fan speed one of the GPUs via telegram. The fan speeds isnt %100 when i check them. Why HiveOS sends constantly %100 fan speed report ?
I couldnt find any solution. There is also no any solution not to get %100 fan speed informaiton. I want to disable fan speed reporting vie telegram boot. But it s not possible. I want to fix fake %100 fan speed report. It is not possible. I talked to support many times but no support. They told me i have to check the fans of the GPUs. But there is no any hardware error. I check the fans manually. No problem. All of them spin normally. When i disable autofan, i can set every speed without any problem. When i enabled autofan, the script works well except fake reporting %100 fan speed. I can see the fans run normal speed not %100. Please find a solution. 16 pcs rigs have this problem. Or you can put a function to disable %100 fan speed report sending. I need it. Autofan max speed is set %95 and it is impossible to spin the fans at %100. I can see there is no %100 fan speed at stats page of the rigs. Why this reports %100 fan speed ?
I have the exact same problem, have you fixed the problem?
Thanks you
With my farm. my fan speed goes to 100% when I restart my miner. when I leave it up for a while it goes back to normal
I found the way to disable %100 fan notification via telegram.
have same problem with my 3070. is there any solution
