0% fan on RTX 3060
Hi guys, I need your opinion on a situation that happened to me yesterday.
I have a rig with 6x RTX 3060, one of my Artic F140 1800RPM fans broke and I replaced it with a Delta 140mm 6000RPM, the CPU temperature dropped dramatically and that’s good but after some time the GPU fans stopped and on Hive the same show 0%.
My questions are, why did the GPU fans stoped, is it normal? will it damage some how from fans or the GPU?
Typically if the fan is still physically spinning (check first) fan showing 0% means the driver crashed usually due to too aggressive memory clocks. Reduce mem and reboot until stable
