I’m using autofan on the cards, with 30% as min. Did set the gpu at a reduced power rate (those 56W are on purpose). Still, this gpu shows 0 fan speed. I went to see the card and the fans work alternately for a few seconds at low rates.
Even though everything is working correctly, and the card is below the targeted temperature. Did set a minimum speed (30%), hoping the fans wouldn’t drop below that.
Some cards sometimes do the opposite. They will go at a higher speed even regardless that the temperature is below the set point.
Could it be a conflict between lolminer and hive?
with a GeForce RTX 3060 Ti 7982 MB · Gigabyte (Samsung GDDR6 · 94.04.46.80.B1 · PL 100 W, 240 W, 250 W).
