I already worked on my 1080 Ti and below is all I can get out of my card. These settings below keeps card memory around 4908 Mhz
With below miner options
its for 1080ti ZOTAC mini?
Hello! This topic is more appropriate. I decided to try different settings and see the result. Here’s what happened. [trex, ethermine, nvd tablet on -50sec]. outside 25C/77F
inv - do not pay attention, these were problems on the server.
Would like to hear your thoughts? Thank you!
Hi can you have a look on mine is well please?
I trying different overclocks and different miners now and still getting similar outcome around 38mh/s on 1080 ti 11gb
Any help or advice will help.
Thank you
Detected 4 NVIDIA cards
GPU BUS ID : 01 05 07 08
CLOCK : 135 100 100 100
MEM : 900 900 900 1200
PLIMIT : 135 125 125 230
FAN : 60 60 60 60
=== GPU 0, 01:00.0 GeForce GTX 1070 Ti 8116 MB, PL: 90 W, 180 W, 217 W === 01:08:35
SET CLOCKS: 0 MHz
SET POWER LIMIT: 135.0 W
Max Perf mode: 3 (auto)
Attribute ‘GPUGraphicsClockOffset’ was already set to 135
Attribute ‘GPUMemoryTransferRateOffset’ was already set to 900
Attribute ‘GPUFanControlState’ (Worker1:0[gpu:0]) assigned value 1.
Attribute ‘GPUTargetFanSpeed’ (Worker1:0[fan:0]) assigned value 60.
=== GPU 1, 05:00.0 GeForce GTX 1070 8119 MB, PL: 75 W, 166.1 W, 200 W === 01:08:35
SET CLOCKS: 0 MHz
SET POWER LIMIT: 125.0 W
Attribute ‘GPUGraphicsClockOffset’ was already set to 100
Attribute ‘GPUFanControlState’ (Worker1:0[gpu:1]) assigned value 1.
Attribute ‘GPUTargetFanSpeed’ (Worker1:0[fan:1]) assigned value 60.
=== GPU 2, 07:00.0 GeForce GTX 1070 8119 MB, PL: 75 W, 166.1 W, 200 W === 01:08:35
SET CLOCKS: 0 MHz
Attribute ‘GPUFanControlState’ (Worker1:0[gpu:2]) assigned value 1.
Attribute ‘GPUTargetFanSpeed’ (Worker1:0[fan:2]) assigned value 60.
=== GPU 3, 08:00.0 GeForce GTX 1080 Ti 11178 MB, PL: 160 W, 320 W, 384 W === 01:08:35
SET CLOCKS: 0 MHz
SET POWER LIMIT: 230.0 W
Attribute ‘GPUFanControlState’ (Worker1:0[gpu:3]) assigned value 1.
Attribute ‘GPUTargetFanSpeed’ (Worker1:0[fan:3]) assigned value 60.
Attribute ‘GPUMemoryTransferRateOffset’ (Worker1:0[gpu:3]) assigned value
1200.
GPU 0, 01:00.0 GeForce GTX 1070 Ti 8116 MB ===
Bios 86.04.85.00.2C, PCIE Link Gen 2, PCIE Link Width 1x
S/N -, UUID GPU-13a21244-28d5-bad1-b8bb-94dfac30c336
Power Limit: Min 90.0 W, Default 180.0 W, Max 217.0 W, Current 135.0 W
Frequency: GFXCore 1885 MHz, MEMCore 4252 MHz
Memory: Total 8116 MB, Used 4488 MB, Free 3628 MB, Micron GDDR5
Utilization: GPU 100 %, MEM 100 %
PSTATE P2, PWR 137.4 W, Temp 68 °C, Fan 60 %, RPM 1943
=== GPU 1, 05:00.0 GeForce GTX 1070 8119 MB ===
Bios 86.04.50.00.63, PCIE Link Gen 2, PCIE Link Width 1x
S/N -, UUID GPU-651e2d95-8de1-f468-a456-ad6dbcffee5c
Power Limit: Min 75.0 W, Default 166.1 W, Max 200.0 W, Current 125.0 W
Frequency: GFXCore 1987 MHz, MEMCore 4252 MHz
Memory: Total 8119 MB, Used 4440 MB, Free 3679 MB, Micron GDDR5
PSTATE P2, PWR 124.3 W, Temp 52 °C, Fan 60 %, RPM 2189
=== GPU 2, 07:00.0 GeForce GTX 1070 8119 MB ===
S/N -, UUID GPU-afa5e946-b767-9327-bfef-2e4bb504c8f2
Frequency: GFXCore 2012 MHz, MEMCore 4252 MHz
PSTATE P2, PWR 125.7 W, Temp 53 °C, Fan 60 %, RPM 2193
=== GPU 3, 08:00.0 GeForce GTX 1080 Ti 11178 MB ===
Bios 86.02.39.00.67, PCIE Link Gen 2, PCIE Link Width 1x
S/N -, UUID GPU-89cb776a-c6f6-3140-dcdc-066b8cba00ee
Power Limit: Min 160.0 W, Default 320.0 W, Max 384.0 W, Current 230.0 W
Frequency: GFXCore 2088 MHz, MEMCore 5702 MHz
Memory: Total 11178 MB, Used 4494 MB, Free 6684 MB, Micron GDDR5X
Utilization: GPU 100 %, MEM 74 %
PSTATE P2, PWR 209.2 W, Temp 50 °C, Fan 60 %, RPM 1672
See my overclocks here:
Will you also know the gtx 1080 memory clock limit?
Holy shit, your temperatures and rejected shares are through the roof mate!
I definately wouldnt push my cards that much. I can post you my cards. Look at my fanspeed, temperatures, wattage and overclocking. Hope it helps!
I just got the same card, I can only get most on 45.1MH using Gminer, --mt 4, core 150, mem -1004, the temp is stable at 60 celeus, The card’s core on my rig cannot crank over 150, or it will loop crash and restart. I guess 45MH is the most I could get, not like some youtube says over 50MH.
11 card set? nice. I feel like 1080ti should be replaced to 2060 super, it generate almost same hashrate but only aroune 100w on 2060s, just hard to find nowadays, I got the Zotac 1080ti mini today, and runs about 45 MH like yours.
Well check the date on those youtube videos since these cards at some point in the past could achieve those numbers but it is constantly diminishing over time. If it is recent it is just not true. These cannot go above 48mhs no matter what you do. I got close to 48mhs when the room temperature was at or below freezing (kept it on my balcony during winter). During the summer I downclocked them to keep the temperatures at bay and fans at 80% so they mined around 42-43mhs.
I sold them off couple of months ago when I wanted to upgrade my mining setup. Got new generation cards, more efficient and less noisy. To be honest couldn’t stand the fan noise, drove me crazy during the summer with 80% fans. But others in the household are missing them already since winter is on the way and they worked exceptionally well as a room heater replacement
From my experience, get the replacement fans in stock they tend to die on higher rpm while working months on end. With both of my cards it was the larger one of the two - I believe that is 100mm fan.
Hey Kompalol,
Are you using the Pill or using MT values on your 1080 ti’s?
I am currently using the pill mate!
Hello can you tell me your extra config codes ?
Extra config codes? I dont have this rig anymore put I posted a picture with what overclocks I was using for that rig.
