XMR-Stak configuration update guide from v2.4 to v2.5
Hey !
I have a big problem with the new algo cryptonightv8… My miner only says “AMD Invalid result GPU ID X”
I tried all miner forks (no fork, indeed-miners and fireice-uk) but I get the same result !
I tried a lot of configurations with someone but impossible to get a good result.
With an other Monero miner (teamredminer), that works perfectly well ! But it is not a miner of Hive and I can’t manage it by Web.
What is the problem with xmr-stak ?
Thanks for your help.
My config :
Motherboard : Z170-A ASUSTeK
CPU : 4 × Intel® Pentium® CPU G4560 @ 3.50GHz
GPUs : 2x RX580 Sapphire Nitro+ 4GB
1x RX570 XFX 4GB
1x RX560 Sapphire Pulse 4 GB
check your config, your miner work, looks like overclock so much
I tried without overclock and all default config.
show your config and your setup
My 4 GPU :
gpu
My miner config :
As i said, i tried several configurations but even by default I get the error.
Currently, I am mining Monero with teamredminer and there is no problem :
My current OC profile for teamredminer :
I run the last HiveOS version 0.5-82
wrong parametr. setup “currency”: “cryptonight_v8”. all param see in the first messedge on this topic
Thanks for your answers :smiley:
But what probability for my problem resolution happens the same day when teamredminer is added to Hive ? :open_mouth:
Edit :
That does not work even with param “currency”=“cryptonight_v8” …
But no problem, after the 0-6 update, i have a large choice of XMR miners.
are you seriously? “currency”=“cryptonight_v8” … OMG
copy and past!!! “currency”: “cryptonight_v8”
Please dude … it was not on purpose to write “=”. I did not check what I wrote in my post.
You really think my miner would work if I had made this mistake ?
So please, don’t reply this kind of post … And calm down !
how to configure and miner to use for mining B2N?
Бился бился так и не смог запустить Cryptonight Red монета mox, хотел в качестве тренировки к 9 марта для монеро попробовать. Но как выяснилось mox выгодная. В конфе пишу
“currency”: “mox”, потом открываю логи майнера, там каких только не предлагается алгоритмов но ни mox ни Cryptonight Red нет. Манеры пробовал XMR-Stak и SRBMiner последний по логам пытается сделать авто-конфигурацию и ставит v8, пул начинает сыпать режектами.
Thanks guys, It’s helpful
GAMEBAISUNWIN - Tập đoàn Casino lớn tại Macao, được biết đến như là Las Vegas Châu Á. Năm 2013 Suncity Group đã đạt được giải thưởng tập đoàn Casino uy tín thế giới. Và hiện tại, SUNCITY cho ra mắt sản phẩm Game Bài đầu tiên mang tên SUNWIN.VN hội tụ đủ mọi đặc điểm của các trò chơi đang hot nhất hiện nay trên di động như: Tiến lên, Poker, Blackjack, Xì Tố… #sunwin #gamebaisunwin #tienlenmiennamsunwin #samlocsunwin #phomsunwin #liengsunwin #xitosunwin #maubinhsunwin #pokersunwin #taixiusunwin #xocdiasunwin #minipokersunwin
Я думаю, с виндой не контачит, операционка какая?
