Has anyone managed to fix this?
There’s a new release 2.4.8
Can anyone compile and try it?
please, how do I get it to go on HiveOS?
I managed to compile it, here’s a tutorial https://www.facebook.com/groups/1933706423562578/permalink/2053586371574582/
Yes 2.4.8 seems fixed problem with cn-heavy. Performance also seems like in original 2.4.3
Going upload to Hive repository
Any idea when it will be up? Will we need to update our hiveOS version?
THX mate, I learned to compile xmr-stak
Managed to implement the fork on the web interface
- Navigate to /hive/xmr-stak
- rm -rf indeedminers
- mkdir indeedminers
- cd indeedminers
- wget http://dl.dropbox.com/s/7utmwn0p7au72n2/xmrstak248.zip
- unzip xmrstak248.zip
Now you can run the miner using the selected fork on the wallet section and it shows up on the web interface
I get a missing shared library libmicrohttpd.so.10
Thank you Octavio for getting it this far.
After running apt-get update
apt-get install libmicrohttpd10 libmicrohttpd-dev libssl-dev libhwloc-dev
The miner started, but the shares are still being rejected. I tried 2 separate pools.
It’s working just fine here.
Did you setup your coin correctly?
xmr-stak was updated 2.4.8 and working fine now both forks
